Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:plugins:vfs_plugins:exported_functions_reference:vfs_movefile
VFS_MoveFile(
     HANDLE:hVFSData,
     LPVFSFUNCDATA:lpFuncData,
     LPTSTR:lpszOldPath,
     LPTSTR:lpszNewPath
→ BOOL
Arguments
hVFSData
lpFuncData
[in] unused
lpszOldPath
[in] Null-terminated string representing the full path of the file to move or rename
lpszNewPath
[in] Null-terminated string representing the new pathname of the file
Return value
The function must return TRUE if the file was successfully moved or renamed, or FALSE on failure. You should set an appropriate error code on failure that Opus can retrieve via VFS_GetLastError.
Description
The VFS_MoveFile function is called to rename a file or folder in your plugin's namespace, or to move a file or folder from one location to another.
You must check the paths provided to determine whether this is a simple rename or a move operation. If you don't support moving of files from one folder to another via a rename you should return FALSE and set the error code to VFSERR_NOT_SUPPORTED - Opus will then fallback to moving the file via copy and delete.
