VFS_Identify(
LPVFSPLUGININFO:lpVFSInfo
→ BOOL
The VFS_Identify function is called when Opus first initializes your plugin to retrieve information about the plugin itself.
The cbSize field of the VFSPLUGININFO structure is used to maintain compatibility between different versions of this API and Opus. You should check the size of the structure specified and make sure you don't attempt to access fields beyond the size specified.
See the Plugin Identification section for more information on the VFS_Identify function.
