Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:plugins:vfs_plugins:exported_functions_reference:vfs_getcustomcolumns
VFS_GetCustomColumns(
     HANDLE:hVFSData
→ LPVFSCUSTOMCOLUMN
Arguments
hVFSData
Return value
If you wish to add custom columns you must return a pointer to a linked list of VFSCUSTOMCOLUMN structures. If you do not want to add custom columns you must return NULL.
Description
The VFS_GetCustomColumns function is called to allow your plugin to add its own information columns to Directory Opus whenever your namespace is displayed in a Lister.
The linked list of VFSCUSTOMCOLUMN structures that you return will not be freed by Opus. It must remain valid for as long as the namespace instance handle remains valid (that is, until VFS_Destroy is called.)
Each custom column must be assigned an ID number via the iID field of the structure. These should be sequential beginning from 1.
See the Specifying Custom Columns section for more information on adding custom columns to the Lister.
