VFS_GetCapabilities(
HANDLE:hVFSData
→ DWORD
The VFS_GetCapabilities function is called to retrieve the capabilities flags of the namespace.
If you are supporting multiple namespaces via the VFSF_MULTIPLEFORMATS flag then the capabilities flags you return may be different for each of your namespace types.
