VFS_ExtractFiles(
HANDLE:hVFSData,
LPVFSFUNCDATA:lpFuncData,
LPVFSEXTRACTFILESDATA:lpExtractData
→ BOOL
The VFS_ExtractFiles function is called to extract files from your plugin's namespace to a local disk file.
The lpszDestPath field of the VFSEXTRACTFILESDATA structure contains the destination path for the extracted files. The lpszFiles is a double null-terminated list of strings, each one specifying a file to extract from your plugin's namespace.
If you do not provide this function then Opus will simulate it with a combination of VFS_CreateFile / VFS_ReadFile / VFS_CloseFile - so unless you are able to extract files more efficiently than this you may feel free to not implement it.
