Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:plugins:vfs_plugins:exported_functions_reference:vfs_destroy
VFS_Destroy(
     HANDLE:hVFSData
→ Void
Arguments
hVFSData
[in] The handle to the namespace instance to destroy
Return value
There is no return value.
Description
The VFS_Destroy function is called to destroy a namespace instance.
You should free any allocated resources and delete the data object as required.
