Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:plugins:vfs_plugins:exported_functions_reference:vfs_create
VFS_Create(
     LPGUID:pGUID,
     HWND:hwndMsgWindow
→ HANDLE
Arguments
pGUID
[in] A pointer to a GUID representing the type of namespace to create
hwndMsgWindow
[in] A window handle with which you can communicate with Directory Opus
Return value
The function must return a HANDLE value which points to a private data structure that provides everything necessary for your plugin to identify and keep track of this namespace instance.
Description
The VFS_Create function is called to create a unique instance of your plugin's namespace.
If you set the VFSF_MULTIPLEFORMATS plugin flag then pGUID will be a GUID retrieved from the VFS_QueryPath function. If the multiple format flag is not set the GUID will be that supplied by the VFS_Identify function.
Currently there are no defined messages that you can send to the window handle supplied in hwndMsgWindow although it is likely this will be used in the future.
