Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:plugins:vfs_plugins:exported_functions_reference:vfs_clone
VFS_Clone(
     HANDLE:hVFSData
→ HANDLE
Arguments
hVFSData
[in] The handle to the existing namespace instance
Return value
The return value is the handle to a new namespace instance of the same type as the passed-in handle.
Description
The VFS_Clone function is called to create a clone of an existing namespace instance.
If this function is not provided and Opus needs to clone an existing namespace it simply falls back to creating a new one via VFS_Create.
