reference:plugins:vfs_plugins:context_and_drop_menus
When the user clicks the right button on a file in your namespace, or drags a file with the right button into your namespace, Opus calls functions in your plugin to build a context menu for display to the user. The two functions responsible for this are VFS_GetContextMenu and VFS_GetDropMenu and they are very similar.
BOOL VFS_GetContextMenu( HANDLE hVFSData, LPVFSFUNCDATA lpFuncData,
    LPTSTR lpszFiles,
    LPVFSCONTEXTMENUDATA lpMenuData )
hVFSData is your namespace instance handle, and lpFuncData is currently unused. lpszFiles is a double null-terminated list of files, providing the full pathnames of the files the user right-clicked on. lpMenuData points to a VFSCONTEXTMENUDATA structure.
By comparison, the VFS_GetDropMenu function is almost identical:
BOOL VFS_GetDropMenu( HANDLE hVFSData, LPVFSFUNCDATA lpFuncData,
    LPTSTR lpszFiles,
    LPVFSCONTEXTMENUDATA lpMenuData,
    DWORD dwEffects )
The only addition to this function definition is the dwEffects parameter which is a mask of the OLE drag-and-drop "effects" currently in use when the drop occurred (that is, DROPEFFECT_COPY indicates the control key was held down, DROPEFFECT_MOVE indicates the shift key and DROPEFFECT_LINK indicates the alt key. DROPEFFECT_NONE indicates no qualifier keys were held down when the drop occurred.)
The VFSCONTEXTMENUDATA structure is defined as follows:
  • UINT cbSize
    This will be set to the size of the VFSCONTEXTMENUDATA structure that Opus is using. This is to maintain compatibility with older versions of the API. You should only access fields up to and including the size of this structure.
  • BOOL fAllowContextMenu
    Set this to FALSE to disallow this context menu, or TRUE to allow it.
  • BOOL fDefaultContextMenu
    Set this to TRUE to have Opus include default context menu items in the context menu shown to the user. Any items you provide will be displayed either above or below the default items. If you set this to FALSE then only the items you provide will be displayed.
  • BOOL fCustomItemsBelow
    Set this to TRUE to have your custom items displayed below the default ones, or FALSE to have your items displayed above them. Has no effect if fDefaultContextMenu is set to FALSE.
  • LPVFSCONTEXTMENUITEM lpCustomItems
    Set this value to point to an array of VFSCONTEXTMENUITEM structures, one for each custom item you wish to add to the context menu. The array can either by statically defined in your plugin, or you can allocate it at run-time using LocalAlloc. If you choose to allocate the menu array at run-time you must set the fFreeCustomItems flag to enable Opus to free the array via LocalFree once it has displayed the context menu.
  • int iNumCustomItems
    Set this field to the number of VFSCONTEXTMENUITEM structures in the array provided by lpCustomItems.
  • BOOL fFreeCustomItems
    Set this value to TRUE to have Opus free your lpCustomItems array via LocalFree once the context menu has been displayed. If you set this to FALSE Opus will not free your array.
The lpCustomItems member points to an array of VFSCONTEXTMENUITEM structures that you supply. This structure is defined as follows:
  • UINT cbSize
    You must set this field to the size of the VFSCONTEXTMENUITEM structure you are using (that is, sizeof(VFSCONTEXTMENUITEM).) Opus uses this value to iterate through the array you provide.
  • DWORD dwFlags
    This is a flags field that controls the behavior and appearance of the menu item. The currently defined flags are:
VFSCMF_CHECKEDdisplays a checkmark next to the menu item
VFSCMF_RADIOCHECKthe checkmark is displayed as a radio button
VFSCMF_DISABLEDthe item is disabled and cannot be selected
VFSCMF_SEPARATORthe item is a separator bar
VFSCMF_BEGINSUBMENUthe item begins a submenu
VFSCMF_ENDSUBMENUthe item is the last in a submenu
  • LPTSTR lpszLabel
    This points to a string that is the label of the context menu item. To assign a hotkey to a menu item prefix the letter with an ampersand (&) character.
  • LPTSTR lpszCommand
    This is the command string that will be executed if the user chooses this menu item.
Note that if you set the fFreeCustomItems flag to TRUE to have Opus free the menu item array, only the memory pointed to by lpCustomItems is freed - the individual strings in each VFSCONTEXTMENUITEM structure are not. Therefore the strings must either be statically defined in your plugin, or must be part of the memory chunk that you allocated for lpCustomItems. Otherwise you may leak memory when the user displays your context menu.
The command string pointed to by lpszCommand defines the command that is executed when the user chooses that menu item. This can be any raw Opus command (for example, "Go OPENINDUAL") or it can be a user-defined command verb. To specify your own commands, select a verb keyword and prefix it with a $ character. This verb (minus the leading $ character) will be passed to your VFS_ContextVerb function when the user selects this command from the context menu. For example, a context menu item whose lpszCommand string was set to "$viewfile" would trigger a call to VFS_ContextVerb with the lpszVerb parameter set the "viewfile".
If you do not want to add your own context menu items and simply want Opus to display default context menus, you do not need to provide the context menu functions.
