reference:plugins:vfs_plugins:configure_and_about
If the VFSF_CANCONFIGURE plugin flag is set, Directory Opus will enable a Configure function for your plugin. This is accessed via the Plugins page in Preferences. When the user selects this function, your plugin's VFS_Configure function is called.
The VFS_Configure function should create and display a dialog that allows the user to configure your plugin. The dialog should be modeless - the VFS_Configure function must return the window handle to Directory Opus.
HWND VFS_Configure( HWND hwndParent, HWND hwndNotify,
    DWORD dwNotifyData )
hwndParent is the parent window handle for your configuration dialog. hwndNotify and dwNotifyData are used to notify Directory Opus that your plugin needs to be reinitialized because of configuration changes.
If the VFSF_CANSHOWABOUT plugin flag is set, Directory Opus will call your VFS_About function when the user selects the About function for your plugin.
HWND VFS_About( HWND hwndParent )
The VFS_About function should create a modeless dialog using hwndParent as the parent window handle, and return the handle to the dialog window. If you do not provide this function then Opus will display a generic About window for your plugin.
