reference:metadata_keywords:keywords_for_setattr_meta
The following keywords can be used to modify file metadata programmatically with the SetAttr META command. Most fields can only be set to a string (or number), or cleared, however some fields accept more complex instructions, and these are noted below.
Field Keyword Notes
Standard Properties
Attributes
attr
Attributes are specified with one or more of the following letters:
A (archive)
R (read-only)
H (hidden)
S (system)
C (compressed)
E (encrypted)
You can also use + to turn attributes on and - to turn attributes off.
Example:
SetAttr META attr:+c-r   - sets compression and clears read-only attributes
Date created
createdate
The date and time can be set to an absolute date (in which case the time will be unchanged), an absolute time (in which case the date will be unchanged), or both.
The accepted formats for an absolute time and date are:
YYYY-MM-DD - set just the date
HH:MM:SS - sets just the time
YYYY-MM-DD HH:MM:SS - sets both time and date (needs quotes)
The keyword now can also be given to use the current date and time.
You can also perform relative adjustments to the current date and time setting, using the following formats:
<time-adjust>  - adjusts only the time
<date-adjust> <time-adjust>  - adjusts both date and time (needs quotes)
The valid formats of the <time-adjust> string are:
[+-]H:M:S  - add or subtract hours, minutes and seconds
[+-]H:M  - add or subtract hours and minutes
[+-]H  - add or subtract a number of hours
The valid formats of the <date-adjust> string are:
[+-]Y:M:D  - add or subtract a year, month and day value
[+-]M:D  - add or subtract a month and day value
[+-]D  - add or subtract a number of days
You can't adjust the date without also adjusting the time - so specify 0 for <time-adjust> if you only want to adjust the date.
Example:
SetAttr META createdate:now   - sets the creation date to the current date/time
SetAttr META createdate:20100922   - sets creation date to Sep 22, 2010
SetAttr META "createdate:20100922 15:30:30"   - also sets time to 3:30 pm
SetAttr META createdate:+1:30   - adds 1h30m to creation time
SetAttr META "createdate:+1 0"   - adds 1 day (and zero hours)
You can also copy the values from another date field by specifying the other field's name: createdate, lastmodifieddate, datedigitized or datetaken. (For backward compatibility, modifydate also works as an alias of lastmodifieddate.)
Example:
SetAttr META createdate:lastmodifieddate   - sets the creation date to the file's last modified date/time
Date modified
lastmodifieddate
Accepts the same values as createdate (described above).
Extended Properties
Comment
comment
usercomment
User-defined string.
Rating
rating
Accepts a value from 0 (to clear the rating) through to 5 (5 stars).
Tags
tags
Accepts multiple semi-colon separated tags. You can either set the tags absolutely, or add tags to or remove tags from the existing set.
Example:
SetAttr META tags:one;two   - sets the tags to "one" and "two"
SetAttr META tags:+one   - adds the tag "one" to any existing tags
SetAttr META tags:+one;-two   - adds "one" and removes "two"
Picture Properties
Aperture
aperture
Accepts either a decimal or fractional value.
Camera make
cameramake
Camera model
cameramodel
Contrast
contrast
Accepts the following values (either the value or the keyword can be used):
ValueKeyword
0normal
1soft
2hard
Example:
SetAttr META contrast:2
Creation software
software
Date digitized
datedigitized
Accepts the same values as createdate (described above in the Standard Properties section).
Date taken
datetaken
Digital Zoom
digitalzoom
Accepts a decimal or fractional value, as well as the keyword off.
Exposure bias
exposurebias
Exposure program
exposureprogram
ValueKeyword
0notdefined
1manual
2auto
3aperturepriority
4shutterpriority
5creativeprogram
6actionprogram
7portraitmode
8landscapemode
Example:
SetAttr META exposureprogram:aperturepriority
Exposure time
exposuretime
Specified in seconds or fractions of a second - accepts either a decimal or fractional value.
F-number
fnumber
Flash
flash
ValueKeyword
0x00noflash
0x01fired
0x05fired,strobereturnlightnotdetected
0x07fired,strobereturnlightdetected
0x08yes,didnotfire
0x09yes,compulsory
0x0dyes,compulsory,returnlightnotdetected
0x0fyes,compulsory,returnlightdetected
0x10no,compulsory
0x14no,didnotfire,returnnotdetected
0x18no,auto
0x19yes,auto
0x1dyes,auto,returnlightnotdetected
0x1fyes,auto,returnlightdetected
0x20noflashfunction
0x41yes,red-eyereduction
0x45yes,red-eyereduction,returnlightnotdetected
0x47yes,red-eyereduction,returnlightdetected
0x49yes,compulsory,red-eyereduction
0x4dyes,compulsory,red-eyereduction,returnlightnotdetected
0x4fyes,compulsory,red-eyereduction,returnlightdetected
0x50no,red-eyereduction
0x58no,auto,red-eyereduction
0x59yes,auto,red-eyereduction
0x5dyes,auto,red-eyereduction,returnlightnotdetected
0x5fyes,auto,red-eyereduction,returnlightdetected
Alternatively, the following codes can be used in conjunction to represent the various states:
  • Y: Flash fired.
  • N: Flash did not fire.
  • S[yn-]: Strobe return; y: detected, n: not detected, -: not present
  • C[yna]: Compulsory; y: yes, n: no, a: auto
  • P[yn]: Flash present; y: yes, n: no
  • R[yn]: Red-eye reduction; y: yes, n:no
Example:
SetAttr META flash:0x50
SetAttr META flash:yes,auto,red-eyereduction
SetAttr META flash:YCaRy
Focal length
focallength
Specified in millimetres - accepts either a decimal or fractional value.
Focal length (35mm)
35mmfocallength
GPS Altitude
gpsaltitude
Specified as metres relative to sea level - accepts either a decimal or fractional value. Specify a negative number to reference below sea level.
Example:
SetAttr META gpsaltitude:-423
GPS Latitude
gpslatitude
Accepts coordinates in any of the following formats:
45:26:46N
45:26:46.302N
45N26 21
45.446195N
45.446195
N45° 26.7717'
45°26'21"N
Example:
SetAttr META gpslatitude:45:26:46.302N
GPS Longitude
gpslongitude
65:56:55W
65:56:55.903W
65W58 36
65.948862W
-65.948862
W65° 56.93172'
65°58'36"W
Example:
SetAttr META gpslongitude:65W58.36
Image description
imagedesc
ISO speed
isospeed
Accepts a numeric value.
Metering mode
meteringmode
ValueKeyword
0unknown
1average
2centerweightedaverage
3spot
4multi-spot
5multi-segment
6partial
255other
Rotation
orientation
Accepts the values 0, 90, 180 and 270.
Also accepts a delta value to adjust the existing orientation value.
Example:
SetAttr META orientation:90   - set orientation to 90
SetAttr META orientation:-90   - rotate orientation 90 degrees counter-clockwise
Saturation
saturation
ValueKeyword
0normal
1low
2high
Scene capture type
scenecapturetype
ValueKeyword
0standard
1landscape
2portrait
3nightscene
Sharpness
sharpness
ValueKeyword
0normal
1soft
2hard
Shutter speed
shutterspeed
Special instructions
instructions
Subject distance
subjectdistance
Specified in either metres or millimetres - accepts either a decimal or fractional value.
Example:
SetAttr META subjectdistance:10.3mm    - 10.3 millimetres
SetAttr META subjectdistance:50m    - 50 metres
White balance
whitebalance
ValueKeyword
0auto
1manual
Music Properties
Album
album
Album artist
albumartist
Compilation
compilation
iTunes Compilation tag. Can be True (1) or False (0).
Cover art
coverart
This can set, add and remove cover art.
To set cover art (removes any existing art), the value must be specified as:
type:<filename>
To add cover art (adds to existing art):
+type:<filename>
To remove cover art (removes any art of a certain type):
-type
The cover art type can be specified as follows (either the value or the keyword can be used):
ValueKeyword
3front
4 back
0other
1icon
2otherfileicon
5leaflet
6media
7leadartist
8artist
9conductor
10band
11composer
12lyricist
13location
14recording
15performance
16vidcap
17colorfulfish
18illustration
19bandlogo
20publisherlogo
Example:
SetAttr META "coverart:3:/mypictures/Pink Floyd.jpg"
SetAttr META "coverart:front:clip"
- sets cover image from the clipboard
SetAttr META coverart:-back    - removes all back cover images
 - removes all images
Disc number
discnumber
Accepts either a single digit (the number of the disc), or two digits separated by a forward slash (the number of the disc and the total number of discs in the set).
Example:
SetAttr META discnumber:3/8
Initial key
initialkey
Original artists
origartist
Release date
releasedate
Accepts YYYYMMDD or YYYY-MM-DD format for the date.
Example:
SetAttr META releasedate:1973-03-01
Track number
track
Accepts either a single digit (the number of the track), or two digits separated by a forward slash (the number of the track and the total number of tracks on the disk). Append a + to the value to activate auto-increment mode.
Example:
SetAttr META track:5/14
Video Properties
Directors
directors
User-defined string. Multiple directors can be separated with semi-colons.
Producers
producers
User-defined string. Multiple producers can be separated with semi-colons.
Writers
writers
User-defined string. Multiple writers can be separated with semi-colons.
Music and Video Properties
Author URL
authorurl
Artists
artist
User-defined string. Multiple artists can be separated with semi-colons.
BPM
bpm
Composers
composers
User-defined string. Multiple composers can be separated with semi-colons.
Conductors
conductor
User-defined string. Multiple conductors can be separated with semi-colons.
Content group
contentgroup
Encoded by
encoder
Encoding software
encodingsoftware
Genre
genre
Mood
mood
Publisher
publisher
Subtitle
subtitle
Year
year
Accepts a four digit year (YYYY).
Document Properties
Authors
author
User-defined string. Multiple authors can be separated with semi-colons.
Category
category
Company
company
Content Status
contentstatus
Content Type
contenttype
Copyright
copyright
Creator
creator
Language
language
Last saved by
lastsavedby
Manager
manager
Producer
producer
Subject
subject
Title
title
