reference:scripting_reference:scripting_objects:configchangedata
If a script add-in implements the OnScriptConfigChange event, the method receives a ConfigChangeData object whenever the user modifies the script's configuration via the Preferences editor.
changed
Vector:string
Returns a Vector containing the names of the configuration items that were modified.
