reference:wildcard_reference:regular_expression_syntax
Regular expressions are a more powerful (and therefore complicated) form of wildcard pattern matching. Like standard pattern matching, they can be used throughout Opus. Generally, you have to specifically enable the use of regular expressions in a given situation - by default, Opus will assume standard pattern matching. For example, the Advanced Rename dialog has a regular expression mode that you must select before regular expressions can be used.
One advantage regular expressions have over standard pattern matching is they can enable a form of search and replace in certain functions. As an example, this is used in the Rename command. The "search" string is specified as a pattern to match against the original names of files. That pattern can indicate capture groups - expressions in the source string that are captured, and can be carried over to the new string (which acts as the "replace" string). As an example, imagine the Rename dialog is set to regular expression mode, with the following patterns supplied:
Old Name: The (.*) Backup\.(.*)
New Name: \1.\2
The two (.*) tokens in the old name string are capture groups - they "capture" whatever is matched by the expression within the parentheses. In this case, the expression inside the brackets is .* which simply means "match anything". So what this pattern will do is match any filename beginning with The and ending in Backup, and it will capture the middle of the filename for later use. The second (.*) will capture the file extension. The new name string can then re-use the captured text, and this is indicated with the \1 and \2 markers. So as an example, the original filename The Lord Of The Rings Backup.avi would be renamed to Lord Of The Rings.avi. \1 refers to the first capture group, \2 to the second, and so on.
If you need the new name string to contain a literal \, use two together. For example, abc\\xyz will turn into abc\xyz.
When used with the Rename command only, the old name pattern can be followed with a # character to indicate that the search and replace operation should be repeated multiple times. For example, the following regular expression rename will remove all spaces from the filename:
Old Name: (.*)\s(.*)#
New Name: \1\2
The # causes the search and replace to be repeated until the new name no longer changes. You can also specify a maximum repetition count by appending a number, for example #5 at the end would repeat the operation no more than five times.
There are many different variants of regular expression; by default Opus uses what's called TR1 ECMAScript. Microsoft has a page on TR1 that goes into far more detail than this help file can.
Token Description
Start of a string.
The caret is used to "anchor" the search to the start of the string. If the search is not anchored to either end, the pattern can match a sub-string of the target.
For example:
^abc matches abc, abcdefg, abc123, but not 123abc
abc also matches// 123abc//
End of a string.
The dollar sign is used to "anchor" the search to the end of the string. If the search is not anchored to either end, the pattern can match a sub-string of the target.
For example:
abc$ matches abc, endsinabc, 123abc, but not abc123
^abc(.*)123$ matches abc123, abcxyz123, but not abcxyz123def
Any single character.
The period (full stop) is used to match any single character.
For example:
a.c matches abc, aac, acc, adc but not acd
0 or more of previous expression.
Matches zero or more occurrences of the previous expression. Combine with . to form the "match anything" token (.*).
For example:
ab*c matches ac, abc, abbc, abbbc, …
a.*c matches ac, abc, a123456c, aanythingc, …
.* matches anything
1 or more of previous expression.
Matches one or more occurrences of the previous expression.
For example:
ab+c matches abc, abbc, abbbc but not ac
0 or 1 of previous expression.
Matches either zero or one occurrence of the previous expression.
For example:
ab?c matches ac, abc but not abbc or abbbc
Alternation (logical or).
The vertical bar is used to separate two or more characters or expressions, any of which may match.
For example:
a|b matches a or b
a(b|c)d matches abd or acd
(bill|ted) matches bill or ted
Quantifier.
Braces are used to indicate that the preceding expression must match an exact number of times.
For example:
ab{2}c matches abbc, but not abc or abbbc
a.{4}z matches abcdez, a1234z, afourz, aaaaaz, etc.
Character set.
Matches any single character in the set of specified characters.
You can specify the character set as individual characters (e.g. [abdfg]) or as a range of characters (e.g. [a-j]) or as multiple ranges.
For example:
[abc] matches either a, b or c
[af-j] matches either a, f, g, h or j
[a-dh-kq-] matches a, b, c, d, h, i, j, k, or any character from q onwards
IMGP[0-9]{4}.jpg matches IMGP0158.jpg (or any other four-digit number).
Negative character set.
Matches any character not in the set of specified characters. See [] for information on how the set is defined.
For example:
[^pqr] matches any character except p, q or r
Expression / capture group.
Parentheses are used to combine multiple characters into an expression. When used in a "search and replace" like Advanced Rename, they also mark capture groups - see above for a discussion of these.
For example:
a|bc matches ac or bc, whereas
a|(bc) matches a or bc
Escape character.
The backslash is used to escape token characters in order to match those characters literally.
When used before a non-token character, it is used to indicate the following special escape characters:
\ttab character ($09)
\rcarriage return ($0d)
\vvertical tab ($0b)
\fform feed ($0c)
\nnew line ($0a)
\eescape ($1b)
\xmatches an ASCII character specified as a two-digit hexadecimal number, e.g. \x20 matches a space
\umatches a Unicode character specified as a four-digit hexadecimal number, e.g. \u0020 matches a space.
It is also used to mark several character classes, which are shorthand ways to specify various common [] character sets (see below).
For example:
a|b matches a or b, whereas
a\|b matches a|b\\ a\t matches a followed by a tab character, whereas
a\\t matches a\t
  \w
Word character.
Matches any word character. Equivalent to [a-zA-Z_0-9].
For example:
^\w+[0-9]{4}.jpg matches IMGP0158.jpg (or any other four-digit number preceded by at least one other word character).
  \W
Non-word character.
Matches any non-word character, equivalent to [^a-zA-Z_0-9].
  \s
Space character.
Matches any whitespace character. Equivalent to [ \f\n\r\t\v].
  \S
Non-space character.
Matches any non-whitespace character. Equivalent to [^ \f\n\r\t\v].
  \d
Digit character.
Matches any decimal digit. Equivalent to [0-9].
  \D
Non-digit character.
Matches any non-decimal digit. Equivalent to [^0-9].
For example:
^\D+\d{4}.jpg matches IMGP0158.jpg (or any other four-digit number preceded by at least one non-digit character).
