In Windows there are a number of virtual folders that are presented as being part of the file system (also known as shell folders). The Desktop folder is an example of a virtual folder. It is a folder that can contain real files (e.g. if you save a document to the desktop, it is stored in a real disk folder) but it also contains virtual items that don't correspond to a real file on a disk (for example, the desktop contains a link to the Recycle Bin, and to the This PC folder).
Opus provides a native implementation of several virtual folders. This means that you can use Opus features like Folder Formats, Power mode or Preferences settings like background images in some commonly used virtual folders. The virtual folders currently supported by Opus are:
When you navigate to a virtual folder other than the ones that Opus implements natively, the Lister acts as a container and hosts an instance of Explorer to provide the display. The advantage of doing this is that it lets you navigate the entirety of the shell namespace from within Opus, including any third-party shell namespace extensions you may have installed.
The disadvantage of hosting Explorer is that to Opus, the folder appears as a "black box". Opus literally has no idea what the contents of the folder are - even the display is provided by Explorer, with Opus doing no more than providing a place for Explorer to put its window. Therefore much of the native Opus functionality is unavailable in these virtual folders.
Some virtual folders, like Computer, are purely virtual - they don't correspond to a real folder on disk.
Other folders, like the C:\Windows\Fonts directory, are real disk folders that have a virtual "overlay" when displayed in Explorer.
The options on the Virtual Folders / File System Preferences page let you control how Opus handles this sort of directory - if desired, you can choose to have Opus display the underlying "real" folder rather than the virtual presentation.
