If a script implements the OnGetHelpContent event, it receives a GetHelpContentData object when the method is called. You can use the methods of this object to add your help content to the Directory Opus F1 help system.
| Method Name | Arguments | Return Type | Description |
AddHelpImage |
<string:name> |
none |
Adds a PNG or JPG image and makes it available for your help pages. You can use any name you like for your images, although they must have either a .png or a .jpg suffix. Your help content can then refer to images by name, e.g. if you add an image and call it myimage.jpg, your html content could show it using: <img src="myimage.jpg"> If your script is bundled as a script package you can include image files in a sub-directory of the package called help, and then load them easily using the Script.LoadHelpImage method. |
AddHelpPage |
<string:name> |
none |
Adds a page of help content for your script to the F1 help file. You can call this method as many times as you like. If you add more than one page of help the first page will become the topic header and all subsequent pages will appear underneath it in the index. |
